Novel Mechanical Fastener Coatings for Corrosion Protection in Dissimilar Material Joints
Back to Core Research Programme 34236-2023-literature-review-on-the-potential-use-of-non-destructive-testing-techniques-for-residual-stress-measurement 34241-2023-artificial-intelligence-for-ndt-scanning-of-unknown-geometries-using-collaborative-robots 34459-2022-friction-stir-welding-of-pressure-vessel-liners-for-the-storage-and-transportation-of-hydrogen 34727-2023-techniques-for-high-temperature-ultrasonic-inspection-of-arc-welding-state-of-the-art-review 34793-2023-update-on-literature-reviews-for-wire-fed-additive-manufacturing 34847-2023-Literature-review-on-crack-length-measurement-techniques-on-environmental-fracture-toughness-tests 35268-2024-Literature-review-on-dual-sensing-applications-for-SHM-of-pipelines 32221-2020-hybrid-composite-to-metal-joining 32893-2020-mechanical-fastener-coatings-for-corrosion-protection 33557-2020-extreme-high-speed-laser-application-ehla-coatings 33557-2020-extreme-high-speed-laser-application-ehla-coatings 33557-2020-extreme-high-speed-laser-application-ehla-coatings 33557-2020-review-of-electric-vehicle-battery-joining-methods-and-testing 34250-2022-thermoplastic-materials-compatibility-for-hydrogen-service A Review of High Power, In-Vacuum and Narrow Gap Laser Welding Processes for Thick Section Welding A Review of High Productivity Additive Manufacture Using a Hybrid Laser-Arc Deposition (HLAD) Process A Review of Micro Welding with Fibre and Disc Continuous-Wave Laser Sources A Review of Residual Stress Measurement Techniques Used for Components Produced Using the Selective Laser Melting Process A Review of the Machine GTAW Ambient Temperature Temper Bead Repair Technique for Nuclear Power Plant Components A Review of Weld Repairs of Mar-M247 and Similar Alloys Applications, Modelling and Manufacturing Processes for Perforated Composites - Literature Review Butt Fusion Welding Procedures and Test Methods Used for PE Pipes Duplex Stainless Steel Welding – A Review of Current Practices Elastic Follow-Up in the Context of Fracture Assessment Flaw Sizing Techniques Using Guided Waves Flaw Sizing Techniques Using Guided Waves Flaw Sizing Techniques Using Guided Waves In-Bore Multi-Positional Laser Welding In-Process Monitoring of Arc Welding for Quality and Defect Detection Mechanical Fastening Technologies for Steel to Aluminium Joining in Automotive Manufacture Process Capability Study for Friction Stir Spot Welding (FSSW) Resistance Spot Welding with Transition Discs – A Review of Dissimilar Joining Using Transition Materials with Specific Reference to Resistance Spot Welding Review of Process Simulations for Metal Additive Manufacturing Surface Modification and Micro-Machining with Pulsed-Laser Sources Wire Fed Electron Beam Additive Manufacture – A State-of-the-Art Review
By Andre Oliveira
Multi-material constructions are used in a range of industrial sectors to optimise the performance of structures. Focusing on the transport sector, the use of metal-to-carbon fibre reinforced polymer (CFRP) and steel-to-aluminium joints is seeing dramatic growth. As these materials cannot be welded together directly, many industrial joining solutions involve the use of mechanical fastening and/or adhesives. Even with successful joining, however, these dissimilar material combinations remain highly susceptible to corrosion. This stems from the galvanic coupling between the materials, which have greatly differing electrode potentials in the operating environment.
Despite the widespread use of fasteners in these applications, reference to the literature indicates that very little development of fasteners, or coatings for those fasteners, has been performed to mitigate corrosion. In fact, only two strategies are used industrially:
carbon steel fasteners with a zinc coating (zinc flake, zinc nickel or zinc-tin); or austenitic stainless steel fasteners (without a coating).
Furthermore, very little corrosion information is available for mechanically fastened dissimilar joints between carbon fibre composites and metal, and reference to the literature indicates that studies to optimise fastener materials and their coatings have not been performed for metal-to-composite joints. This is in spite of widespread concerns regarding durability. In production cars, for example, dissimilar joints of this type are used almost exclusively in ‘dry’ areas of vehicles, where exposure to water, salt and stone chipping from road surfaces does not occur. To reduce further the risk of corrosion-induced failure, dissimilar material joints in cars are usually coated with sealants, electrolytically deposited zinc-phosphate crystals and multiple layers of paint and lacquer. These measures are taken because if, the paint layers are penetrated and the joints become exposed to electrolytes (moisture, salt water from the road, etc), rapid deterioration of the fastener and thus the joint then occurs.
The focus of this review is therefore to examine fastener-coating developments that can improve the corrosion performance of dissimilar metal to composite joints. Note that coating systems that act as a barrier preventing the electrical interaction between materials can potentially have applications across a range of dissimilar materials combinations, including not only metal to CFRP joints but also aluminium to steel.
 32893_Image_01
Zinc-coated carbon steel rivet in an aluminium to CFRP joint, exposed to 96 hours of salt spray: total rivet failure occurred.
