Powder Metallurgy Hot Isostatic Pressing (PM HIP) Manufacturing Services
Powder metallurgy hot isostatic pressing (PM HIP) combines powder metallurgy (PM) with hot isostatic pressing (HIP) technology to produce fully dense, high-performance engineering parts for a range of industrial applications.
The process works by design and fabrication of a leak-proof deformable canister, which is filled with ceramic or metal powders before outgassing (to remove moisture content and gaseous species), and seal-off. The powder filled canister is then loaded inside the HIP furnace, where it is heated - usually up to 0.8Tm (the melting point of powder material) - and subjected to a uniform inert gas pressure in the range of 100MPa to 150MPa for a few hours of dwell time to consolidate the powder into a fully solid, semi-finished, near net shape part. The finished part become ready after the secondary machining operation.
The PM HIP process uses the combination of high pressure and high temperatures to consolidate the alloy powders and create near net shape parts with similar or superior mechanical properties as compared to wrought material.
How It Works
PM HIP manufacturing process requires six steps, as follows:
  1. Canister Fabrication: A deformable metal mould or capsule is designed and fabricated in the shape of the part to be manufactured, although slightly larger than the desired finished product
  2. Encapsulation: The canister is filled with powder before being outgassed and, finally, sealed off
  3. Heating: The powder filled canister is then loaded inside the HIP chamber where it is heated to a temperature that is below the melting point of the powder medium e.g., 0.7 to 0.8Tm
  4. Pressure: A high-pressure inert gas (typically argon) is introduced into the chamber to apply a uniform pressure (100MPa ~150MPa) onto the canister while heating
  5. Powder Consolidation: The combination of temperature and pressure causes the metal powder particles to diffusion bond/fuse inside the canister, removing any internal pores and causing the part to shrink to the desired size and shape
  6. Finished Part: The finished part can then be machined from the hot isostatically pressed (HIPed) canister, although some materials may require further heat treatment - such as annealing, solution and aging treatments - following the PM HIP powder metallurgy process
Press Releases
Find out more about powder metallurgy hot isostatic pressing at TWI:
Core Research
Find out more here
Joint Industry Projects
Find out more here
Key Advantages of PM HIP Manufacturing
Powder metallurgy hot isostatic pressing offers a range of benefits for industry, including:
  • High Density Parts: Capable of producing parts with close to 100% density
  • Improved Mechanical Properties: The PM-HIP process improves fatigue resistance and increases strength and ductility by eliminating internal porosity
  • Near Net Shape Manufacturing: PM HIP reduces or eliminates the need for post-process machining by creating parts to their desired final shape and size
  • Flexibility of Design: PM HIP can form parts with complex geometries as well as being able to combine dissimilar materials
  • Material Innovation: Allows for the creation of parts with innovative material combinations for demanding applications, including metal matrix composites (MMCs) and functionally-graded materials (FGMs)
  • Faster Production: PM HIP provides a faster production route compared to traditional manufacturing methods such as casting and forging
  • Fewer Supply Chain Issues: Cast or forged products suffer from supply chain issues that can be overcome by PM HIP technology, offering a faster route to manufacture high quality industrial parts
  • Reduced Costs: Because PM HIP creates near net shape parts with reduced supply chain length, there are fewer processing steps and material wastage than with processes that require post-processing, hence saving costs
  • Improved Sustainability: Less material wastage also means a more environmentally-friendly and sustainable process
The multiple benefits of PM HIP advanced manufacturing technology have led to its adoption by several industries, including aerospace, oil and gas, automotive, nuclear, and medical; manufacturing components ranging from landing gears, aeroengine casings, manifolds, valve bodies and pressure vessels, to medical implants and high-stress automotive parts.
PM HIP at TWI
With decades of experience, our experts are among the global leaders in the PM HIP process, providing dedicated and bespoke industry support, guidance and advice to our Industrial Members.
Hot isostatic pressing (HIP), which was first used in 1955 for diffusion bonding activities, has seen a renewed interest for next generation, high-integrity applications that require high performance components. PM HIP has also become a practical solution to the supply chain issues associated with the manufacture of large parts by casting; dramatically reducing lead times for a range of industries.
With pressures comparable to that found in the depths of the Mariana Trench (1,086 bar), hot isostatic pressing (HIP) has found a number of additional industry applications outside of PM HIP, including to densify castings and pre-sintered components, and as a post-thermal treatment for additive manufacturing, where the application of pressure and heat can fully consolidate materials including steels, stainless steels, nickel base superalloys, titanium alloys, refractory alloys, and more.
As expertise in many traditional manufacturing becomes less widespread and lead times and supply chains lengthen, PM HIP and HIP, being alternate processes, have the potential to overcome supply chain issues and to reduce costs and material waste, shorten lead times, and allow for the creation of coherent, net shape parts from similar and dissimilar materials. Capable of meeting increasingly complex design and operating conditions, PM HIP is a viable alternative to traditional manufacturing processes, offering as much as a 90% reduction in material wastage (along with the associated sustainability and environmental benefits), while also offering superior mechanical properties.
Despite the multiple benefits, many industries are yet to adopt the process. TWI is working with our Industrial Member companies to help address the challenges and remove the barriers to adopting PM HIP and HIP processes in their manufacturing.
Our experts can advise on the use of the process as well as using our facilities to carry out process development, testing and prototyping for your targeted industrial parts.
PM HIP and HIP Services
TWI provides technical excellence for industry in the following areas:
  • Prototyping
  • PM HIP Modelling Tools
  • Metal Powder Analysis
  • Canister Design and Manufacturing
  • Powder Filling (under ambient, vacuum or inert conditions)
  • Outgassing (room or elevated temperature)
  • Crimp and Seal
  • HIP Treatment
  • Dimensional Measurement (GOM Scanning)
  • Heat Treatment
  • Destructive and Non-Destructive Testing
  • HIP Diffusion Bonding of Dissimilar Materials
  • Certification and Qualification
To find out more about HIP and PM HIP, as well as to see how we can help solve your industry challenges, please email contactus@twi.co.uk.
