Thermal Spray Additive Manufacturing
Thermal spray additive manufacturing (TSAM) uses a high velocity heated gas to propel molten or softened powder / wire material against a substrate, where the particles bond layer-by-layer. As well as being used to create 3D parts, the process can apply functional coatings with enhanced properties such as improved wear or heat resistance.
Key TSAM processes include:
  • Plasma Spraying: Suitable for both ceramics and metals this process uses high temperature plasma jets that creates dense, high-performance layers
  • High Velocity Oxygen Fuel (HVOF): Combustion gases are used to achieve high particle velocities that create hard, wear-resistant layers
  • High Velocity Air Fuel (HVAF): Uses compressed air and fuel, creating lower temperatures which are compensated by higher velocities and less oxidation, resulting in tougher, corrosion-resistant and less porous coatings
  • Cold Spray (CS): Additive materials are heated to below melting point but delivered to the substrate at supersonic speeds, where mechanical deformation causes the bond, creating dense layers with fewer defects
Blending traditional coating techniques with modern additive manufacturing, TSAM has found applications across industries including aerospace, energy, biomedical and automotive, where it is favoured for the ability to create wear resistant parts, deliver functional surfaces, and provide specialised component repair.
Advantages of TSAM
TSAM provides several advantages for industry, including:
  • Materials Options: TSAM can create parts from a single material or with composite, graded or multi-layered structures
  • Improved Properties: Can create functional surfaces and parts with improved corrosion, thermal and wear resistance
  • Repair: TSAM can be used to repair and upgrade existing parts, saving costs and extending service life
  • Cost and Environment: TSAM reduces material waste compared to subtractive methods as well as allowing for the recycling and reuse of expensive additive materials, which is better for both costs and the environment
Core Research
Find out more here
Joint Industry Projects
Find out more here
Thermal Spray Additive Manufacturing at TWI
TWI provides technical excellence in all aspects of thermal spray additive manufacturing (TSAM), drawing upon years of expertise in additive manufacturing, materials and thermal spray processes.
We can provide feasibility and design support, guidance on every aspect of TSAM adoption, as well as advice on how to maximise the process for the specific industry needs of our Industrial Members, aligned to relevant sector or business requirements.
Our facilities are also equipped to provide one-off manufacturing support and prototyping, allowing our Industrial Members to use our equipment as an extension of their own.
TWI’s TSAM support also includes business case proposals, numerical modelling and topology optimisation, material and process selection, finishing, heat treatments, testing, certification and validation, as well as support with relevant standards.
To find out more about TSAM and how we can support you with its use, please email contactus@twi.co.uk.
