Aggressive Environment Testing
Aggressive Environment Testing Banner
Innerpage Title Banner
Aggressive environment testing (AET) assesses how materials and components withstand extreme conditions such as high pressures and temperatures, corrosive substances, or combinations thereof, measuring their effects on mechanical properties, flaw tolerance, and overall durability. This testing is often a form of destructive testing, involving tests such as corrosion, fatigue, and fracture tests (including tensile testing) to identify failure points and ensure reliability for demanding applications in sectors like oil and gas and aerospace. These tests can inform asset owners of the long term effects of aggressive environment exposure as well as identifying internal stresses and causes of residual stress.
Designed to evaluate the performance of both materials and finished products under harsh operating conditions, AET involves subjecting components or materials to these environments to understand their limits before being put into service.
Common Aggressive Environments and Tests
Common aggressive environments that warrant tests include:
  • Corrosive Environments: These are acidic conditions such as those found in ‘sour’ (H2S) or ‘sweet’ (CO2) environments
  • High Pressure and Temperature (HPHT): High pressure and temperature environments are often encountered in deep sea applications, such as those encountered in the geothermal or oil and gas industries
  • Fatigue Crack Growth: This specifically assesses how cracks grow under constant or variable loading in an aggressing environment
  • Fracture Testing: This measures a material’s resistance to fracture under extreme conditions
  • Exposure to Hazardous Substances: This is the testing of a material when subjected to a hazardous substance such as chlorine
Benefits of Aggressive Environment Testing
Aggressive environment testing offers several benefits, including:
  • Assessing Durability: Providing information to understand a material’s resistance to failure and flaw tolerance under severe conditions
  • Identifying Weak Points: AET allows you to locate design weaknesses and potential performance limitations before a part is put into use in the real world
  • Providing Reliability: Understanding the limitations of a material of component allows you to gauge the operational and storage requirements in different sectors
Aggressive Environment Testing at TWI
If your business operates in environments in which very high or low temperatures or pressures are a factor, or involves working with hazardous substances, our dedicated environmental testing facility can give you confidence in your components.
We test the performance of materials and joints in aggressive environments, measuring the effect of the conditions on a part's mechanical properties or flaw tolerance.
Insights
Find out more about aggressive environment testing at TWI:
Core Research
Find out more here
Joint Industry Projects
Find out more here
Bespoke Testing in Extreme Environments
Forming a significant part of our 6000m2 of workshop and laboratory space, our high-pressure, high-temperature (HPHT) testing facility enables mechanical tests to be carried out on components in environments that replicate the service conditions of applications in sectors including oil and gas, aerospace and nuclear.
Typical examples of test types carried out at TWI include the following:
  • Fatigue crack growth, tensile strength and fracture tests in environments with pressures up to 450 bar, at temperatures between -50°C and +80°C
  • Exposure to temperatures up to 300°C, at pressures up to 1400 bar
  • Corrosion testing in oxygen and chlorine at up to 80°C
  • Permeation testing at temperatures up to 250°C and pressures up to 650 bar
  • Full-scale sour service fatigue testing
  • Hydrogen testing
Visit our environmental testing of polymers and non-metallic materials page for information on our aggressive environment testing services for non-metallics.
Large, Specialised Testing Rigs
To meet the needs of our Industrial Members, TWI has constructed several bespoke testing facilities that mean we are uniquely placed to carry out highly specialised tests that can be precisely tailored to your requirements:
Underpinned by 70 Years of Industrial Experience
Many companies offer testing services, but our technical excellence goes far beyond simply carrying out tests. We work closely with our Members to interpret results and deliver genuine insights that can be easily translated to operational decisions, providing actionable remedial advice that directly impacts the bottom line.
Contact us to discuss your needs and see how our unique aggressive environment testing facilities can be used to create bespoke solutions to your challenges or improve your processes, save costs, and increase asset or component lifecycles and safety.
