Hybrid Laser Arc Welding at TWI
Hybrid laser-arc welding is a joining process simultaneously combining laser welding and arc welding in the same weld pool. In theory, the beam from any welding laser source (CO2 , Nd:YAG, diode, Yb fibre, Yb:YAG disk etc) can be combined with any arc process (MIG/MAG, TIG, SAW, plasma). Typically, however, hybrid laser-MIG/MAG and laser-TIG are the most common combinations for hybrid laser arc welding processes.
Hybrid laser arc welding requires high power lasers and a high-quality beam for deep penetration, especially when welding thick materials.
However, as a hybrid process, it has the individual advantages of both arc and laser welding processes. Deep penetration hybrid welds can be made, comparable with the penetration depths achieved by laser welds but, at the same time, having a tolerance to joint fit-up and a weld cap profile more comparable with arc welds. Furthermore, arc welding consumables (and gas mixtures) can be used, offering a degree of control over weld quality and properties than is possible with autogenous laser welding.
Example Applications
Hybrid welding is already being used, or under consideration, by the following industries:
  • Road transport – the high welding speed of the hybrid process is attractive to the high production volume environments found in the automotive industry, especially given the greater part fit-up tolerance than with autogenous laser welding
  • Shipbuilding – the lower heat input and distortion introduced when hybrid welding, when compared with MAG welding or SAW, reduces the costs associated with distortion correction and rework. By contrast, conventional arc welding methods and their associated re-work have been estimated to constitute up to 20-30% of overall manufacturing costs
  • Rail transport – as in shipbuilding, the low distortion that can result from hybrid railcar seam welding, compared with conventional arc welding processes, is of interest as a means of reducing fabrication costs, as well as the high productivity welding speeds, which reduce overall welding time
  • Oil and gas – the hybrid welding of pipes has been well demonstrated, and with continuing developments in laser sources and pipe steels, continues to be of interest as a future means of increasing overall joint completion rates, depending on steel grades used and operating environment requirements
Advantages of Hybrid Laser Arc Welding
The chief benefits of hybrid laser-arc welding include:
  • Improved tolerance to joint fit-up; for example, hybrid welding can extend the tolerance to joint gap by a factor of at least 2-3 times over laser welding, or greater, if real-time adaptive control of hybrid welding parameters is carried out
  • Improved weld quality; hot cracking (e.g. in some higher strength Al alloys) can be avoided, and internal porosity content reduced, with respect to laser welds
  • Increases in single pass penetration depth; this is controlled principally by the choice of laser and welding parameters used, but single pass penetrations >6-12mm can be achieved using higher power (≥5kW) lasers
  • Increases in welding speed; this is also dependent on the laser used and materials being welded, but high speeds of >5m/min can be possible in thinner materials
  • Reduced Distortion;  Reducing the net heat input can result in lower distortion, rendering hybrid welding of particular interest for the making of long seam welds between plates and sections, or for the welding of attachments, etc.
Combining arcs and lasers, hybrid laser arc welding can offer the benefits of both techniques. The increases in penetration depth and/or welding speed, when compared with arc welding, are particularly significant, while the use of filler wire can help improve control and thereby produce higher quality welds than with autogenous laser beam welding.
Core Research
Find out more here
Joint Industry Projects
Find out more here
TWI has decades of experience of hybrid laser-arc welding processes and their development. This includes combining a variety of industrial welding laser sources (including CO2, Nd:YAG and Yb fibre lasers) with both MIG/MAG and TIG arc welding.
Furthermore, TWI’s research and development in this area has covered a broad base of engineering alloys, welding metal alloys including C-Mn steels for both structural and pipeline applications, conventional (austenitic) and higher strength (duplex and ferritic) stainless steels, and a wide range of aluminium alloys that have been used for light engineering, road transport and aerospace applications.
Our experts have also carried out a number of hybrid welding development and implementation projects, funded through its own Core Research Programme (CRP), Joint Industry/Group Sponsored Projects, and European-funded Collaborative Projects, as well as confidential evaluative or developmental work for our Industrial Members.
Examples of TWI’s work in hybrid welding include:
  • CO2 laser-MAG welding of butt joints between C-Mn steel plates, including assessments of joint gap bridging ability, weld qualities and properties, for shipbuilding applications
  • Robotic Nd:YAG laser-MAG welding of T joints between C-Mn steels, and their resulting properties, also for shipbuilding applications
  • High speed, low distortion hybrid welding of aluminium alloys using Yb fibre lasers, for rail transport applications
  • The development of low internal porosity content hybrid welding methods for aerospace aluminium alloys
  • The development of hybrid welding for conventional and higher strength stainless steels
  • The development and demonstration of real-time joint monitoring and process control when hybrid welding butt joints in steels, stainless steels and aluminium alloys
TWI’s combined research and project expertise ensures our Industrial Members have access to the required technical excellence to gain the full benefits of using this process.
To find out more and see how we could assist with your hybrid laser arc welding challenges, please email contactus@twi.co.uk.
