Thermal Spray Coatings
Materials Banner
Innerpage Title Banner
Contact Us CTA
Thermal spray coating involves spraying molten or semi-molten coating materials onto a surface to improve or modify its properties, making it more corrosion resistant, wear resistant, or durable. This can be achieved, for example, through metal spraying a substrate with a coating of stainless steels. The process uses thermal energy, like a flame, plasma, or arc, to heat the coating material, which is then propelled onto the substrate where it cools to form a thin layer on the base material.
Thermal spraying can be used to deposit metals, cermets (such as WC-Co), ceramics, or polymers in layers typically 60 μm to 10 mm thick, for a wide range of engineering applications. Almost any material can be deposited, so long as it melts or becomes plastic during the spraying process. Blends of different materials to produce composite or graded thermal spray coatings are possible. At the substrate surface, the particles form 'splats' or 'platelets' that interlock and build up to form the coating.
The deposit does not fuse with the substrate or form a solid solution. Instead, the bond is primarily mechanical, based on the melting and acceleration of the coating material. Hence, adhesion depends on the molten particle velocities at impact as well as the surface condition, which must be clean and roughened by grit blasting or machining prior to spraying. Bond strengths between ca. 10 MPa and >80 MPa can be obtained, depending on the thermal spray coating process and spray parameters used.
Conventional thermal spray techniques include flame spraying and electrical arc spraying. These have been used since the mid-1900s and continue to be developed. More advanced thermal spray processes include detonation gun, high velocity oxy-fuel (HVOF) (for tungsten carbide), plasma, and suspension/precursor spraying. Each process gives different coating characteristics for the same coating material, which determines the coating performance.
Thermal Spray Process
The thermal spray process works as follows:
  • A coating material, often in powder / wire form, is fed into a spray gun
  • A thermal energy source, such as a flame, arc, or plasma, melts or vaporises the material
  • The molten material is then propelled at high velocity onto the substrate
  • As the particles strike the surface, they flatten and cool, forming a strong, bonded coating
  • The thickness of the coating can be controlled by repeating the process
Insights
Find out more about thermal spray coatings at TWI:
Core Research
Find out more here
Joint Industry Projects
Find out more here
Thermal Spray Applications
Common applications for thermal spraying include the repair of rotating and moving parts for vehicles, pumps and other machinery, protective coatings to prevent wear and corrosion, and specific material coatings for electronic components, parts for power generation, and other industry requirements.
Thermal spraying processes can offer a technically superior and commercially competitive solution to many industrial challenges, including:
  • Replacement of chrome or cadmium plating
  • Wear, corrosion and thermal protection, e.g. biomass and waste-to-energy plants, offshore structures, subsea pump internals, impeller wear rings, valve plugs/balls/discs and seats, rock drill internals, compressor blades and vanes, bearing housings, glass plungers, printing rolls, textile guides
  • Biocompatible coatings on orthopaedic and dental implants
  • Dielectric coatings for electrical insulation in power hybrid circuits and heating elements
  • Spray forming, e.g. manufacture of thin walled hollow cylindrical objects from pre-shaped cores
  • Component surface restoration after wear or damage
Benefits
 Thermal spraying can improve the life of machinery, structures and components, reducing the costs associated with maintenance and unexpected downtimes. Thermal spraying can prevent the need to replace a part and is applicable to a wide range of industries.
Conductive coatings use materials such as copper, aluminum, or silver to create a pathway for electrons, while insulating (dielectric) coatings use materials like aluminium oxide or yttrium to create a non-conductive, thermal barrier layer for applications such as shielding. The final electrical properties depend on the intrinsic properties of the sprayed material and the microstructure of the resulting coating, including electrical conductivity.
Thermal Spray Coating at TWI
TWI has decades of experience with thermal spray coatings – providing support and advice to industry on all aspects of thermal spraying. The services we provide for our Industrial Members include:
  • Applications development
  • Coatings research and development
  • Consultancy services and materials selection
  • Coating failure investigations
  • Coating characterisation and testing
We use a wide range of commercially-available thermal spraying equipment, so that technology developments are easily transferable to industry. The available process technologies are:
  • Latest generation cold spray system
  • Three different HVOF systems
  • Plasma spraying (APS)
  • Twin wire arc spray
  • Flame spray
In addition, we have undertaken several research projects related to thermal spraying, including the development of improved sacrificial coatings for seawater corrosion resistance of steel structures, corrosion mitigation of boiler tubes in biomass or waste-to-energy plants, and the development of antifouling coatings for renewable energy applications.
To find out more about thermal spray coatings and how we can help you solve your industry challenges, please email contactus@twi.co.uk.
