TWI’s history of welding and joining innovation spans many decades, but continues into the present with the creation of new techniques across a range of industries and materials…
- TWI Develops Wood Welding Process
We developed a method using linear friction welding to join pieces of wood in less than ten seconds. This fast bonding, wood welding process eliminates the need for mechanical joining methods like screws or nails while also avoiding the use of adhesives (figure 6). These factors offer potential benefits for the environment, making recycling a safer and easier, environmentally-friendly process. Interested parties contacted us following this innovation in order to explore its use for a range of potential applications such as the high volume manufacturing of items like furniture, barrels or even food containers.
This innovation continued through a partnership with Zero Glue Bamboo for a series of trials to weld bamboo without adhesives or fasteners…
- Welding Bamboo: The Future is Zero Glue
Taking our experience from earlier wood welding trials, we undertook trials to bond strips of bamboo using linear friction welding (LFW), creating a faster, cleaner and more sustainable bonding method and eliminating the need for toxic, fossil-fuel-based glues that currently dominate the industry. The trials successfully showed that bamboo could be joined using LFW in under two seconds, with a weld strength comparable to the bamboo itself and with a full bond across the entire interface (as confirmed with microscopic analysis). With a range of potential applications, this innovation provides a more competitive and genuinely sustainable alternative to conventional engineered bamboo and wood products (figure 7).
Other innovations include the granting of a diffusion bonding patent in 2023 for the diffusion bonding of aluminium…
- TWI Granted Diffusion Bonding Patent
We were pleased to receive a United States patent for the new diffusion bonding technique with a surface coating material that can be used for compact heat exchangers, heat sinks, cooling loops, process intensification units, and more. This proprietary technique allows for the successful diffusion bonding of aluminium with achievable joint strengths comparable to the heat-treated parent material. Invented at TWI, the technique produces an autogenous joint without the requirement of interlayers or melting point suppressants, with tests showing that the technique may demonstrate a viable route for the manufacture of compact features and other devices containing complicated internal pathways.
Of course, our work does not only include the creation of new solutions for industry, but also the development of existing welding and joining techniques into new realms…
- Handheld Laser Welding for Industry
A new joint industry project (JIP) has been launched allowing interested parties to get involved and gain exclusive access to research around the industrial adoption of handheld laser welding technology (figure 8). Handheld laser welding looks set to promise faster, more versatile, cost-effective and consistent results than conventional, manual arc welding processes such as MIG/MAG or TIG welding. However, there is still a lack of standardised assessment methodology and supporting data to validate the claims of the technology, making industry hesitant to adopt the process. This project is focussed on the ability to make sound welds, health and safety, environmental impacts, and the tolerance of the process in relation to weld quality and mechanical properties. This includes an independent validation of the technology’s performance, robustness, safe operation and capabilities, as benchmarked against conventional manual arc welding approaches (including MIG/MAG and TIG welding processes), to provide an industry-ready comparison.
One area where we have seen development in recent years is the use of welding for space applications, with TWI expertise being used for a number of new innovations and breakthroughs…
- TWI Helps Achieve World’s First Autonomous In-Space Weld
ThinkOrbital Inc. called TWI ahead of a test mission to perform the first-ever autonomous weld in space. Our experts have years of experience in building bespoke electron beam welding solutions for industry, making us the perfect partners for this history-making event. An electron beam gun, which was designed and created at TWI, was loaded aboard the Falcon 9 and performed the world’s first autonomous in-space weld on 6 May, 2024. The electron beam welding samples were returned to Earth for analysis by NASA and the European Space Agency. A real milestone in the journey towards mature technologies being used for the autonomous assembly of space stations in a single launch, this innovation also opens up the potential for advances in satellite servicing, space debris processing, in-space manufacturing, on-orbit storage and refuelling, space tourism, and scientific research.
But it isn’t just electron beam welding that has been developed for space use at TWI, as a new project looks set to deliver the UK’s first in-space robotic welding capability – using arc welding as the solution…
- Developing A Robot-Mounted, In-Space Arc Welding System
The recently-launched ISPARK project aims to develop a robot-mounted arc welding system for in-space repair, joining and future orbital manufacturing. Welding in space faces a number of significant challenges, including the vacuum environment, microgravity, and thermal instability, as well as the inherent danger and intense physical demands placed on astronauts. These challenges have meant that performing welds in space is a rare and technologically challenging undertaking. The ISPARK project aims to overcome these challenges through the creation of a new, space-qualified robotic welding capability that enables autonomous, in-orbit repair and manufacturing. Our experts are working on the project alongside those from the University of Leicester. Bringing together industry and academia, ISPARK will include vacuum environment trials to check the performance of the welding system, and digital twin modelling simulations for additional data to help validate key technologies before eventual use in the complex thermal, radiative and dynamic conditions of real spaceflight.
These are just some examples of the welding and joining solutions being pioneered by TWI for the benefit of industry, to find out more about the welding and joining expertise that we provide to industry and how we can help you, please see here:
https://www.twi-global.com/what-we-do/research-and-technology/technologies/welding-joining-and-cutting
