Also known as Guided Wave Testing (GWT), Guided Wave Long Range Ultrasonic Testing (GWLRUT) is a long-range, non-destructive testing method that uses low-frequency, guided ultrasonic waves to inspect long, in-service, or inaccessible pipes, rails, plates and other structures for corrosion, erosion, and cracks.
Sound waves are generated by transducers from where they travel along the surface of the structure until they encounter a defect that has caused a change in the thickness of the structure, such as cracking or metal loss from corrosion. The defect causes a pulse echo to be sent back that can be analysed to characterise, identify and locate the defect. The benefits of this process include being able to screen large and hard-to-access areas from a single test point, which has seen it used in industries including oil and gas, where it can be used to inspect sleeved or buried pipes as well as those that are ‘unpiggable’ or hard to inspect by other means.
TWI has been instrumental in developing this process for industry through a range of different projects over the decades. These include core research programme (CRP) projects that are created for the wider benefit of our Industrial Members (who can all access the outcomes of the research), as joint industry projects (JIPs) which allow interested parties to act as sponsors in return for the project outcomes, during public-funded project work where we typically work as part of a consortium made up of other industrial or academic organisations for the wider benefit of industry and society, or directly on behalf of individual Industrial Member companies.
This combined research has afforded TWI a level of expertise that is trusted by many of the largest names in industry, including in the use of guided wave long range ultrasonic testing. Some examples of our work in this area include…
Core Research Programme
The core research programme (CRP) allows our experts to conduct research and development activities for the benefit of our Industrial Members. The outcomes of our CRP projects are available to our Industrial Members and typically involve advancing a process, innovating new solutions, and addressing industry challenges. CRP projects cover a range of industries and capabilities, including GWLRUT.
- Electromagnetic Transducers to Generate/Detect Guided Waves
This 1999 project was created to assess the use of electromagnetic transducers to generate long range low frequency guided waves for detecting environmental damage in ferritic steel pipes. This foundational work investigated the replacement of piezoelectric transducers, which required the pipe surface to be exposed and any excess corrosion to be removed, with electromagnetic transducers (EMATs), which are not adversely affected by poor surface conditions, operate through coatings, and are relatively cheap to manufacture.
- Finite Element Analysis of Guided Waves in Pipe/Rail Flaws
Having shown that GWLRUT could be used to screen large areas of pipe from a single location, this 2003 project investigated the potential for the technique to be applied to the detection of flaws in rails. In addition, our experts worked to validate a new wave propagation modelling technique against experimentally measured transmission data in a steel plate and to quantify the reflection characteristics of guided waves from flaws in pipes.
- Improved Guided Wave Technology for Pipe Defect Detection
This 2007 project sought to advance long range ultrasonic inspection by finding an effective technique for focusing guided waves into one region of steel pipe, which would increase the sensitivity to defects, making it easier to size and position them. This would reduce the time and cost required for inspection as well as open up the possibility of steering the beam around bends in pipes. The focussing technique was tested against a range of pipe geometries as our experts also assessed the potential for sizing corrosion damage using techniques for modelling the focusing of guided waves.
- Sizing Locally Thinned Areas and Guided Wave Pipe Inspection
Although guided waves had found use for the corrosion screening of straight sections of industrial pipeline, there remained challenges around its use on pipelines with bends as well as for distinguishing between uniform circumferential thinning and a severe patch of localised corrosion at one circumferential position. This 2008 project addressed both of these challenges through the quantification of pipe bends on guided waves as well as creating a technique to size locally thinned area defects in straight pipes using guided waves.
- Long-Range Guided Wave Inspection Beyond Pipe Bends
This project built upon the findings of the previous one through the use of insight modelling to quantify the effects of pipe bends on guided waves for a range of pipe bend angles. In addition the TWI project team developed signal reconstruction techniques to overcome the effects of pipe bends on the propagation of guided waves.
- Long-Range Guided Wave Pipe Modelling and Inspection
Continuing the investigation into the effect of pipe bends on ultrasonic signals, TWI’s experts used finite element modelling to assess the behaviour of guided wave propagation around pipe bends. The results of this finite element assessment were then experimentally validated before a technique was created for the correction of the signal distortion caused by propagation around a bend.
- Guided Wave Inspection of Plate-like Structures
This 2019 project sought to develop and evaluate a new transducer array design suitable for performing guided wave testing on plate-like components such as bridges, storage tank floors and large diameter cylinders like storage tanks walls, pressure vessels and wind turbine support structures. The aim of the technology was to open up a route to reduced cost structural health monitoring for a range of different industries. The TWI team created a prototype ‘omnidirectional SH0 transducer,’ incorporating a localised circular array of eight commercially available piezoelectric thickness-shear monolithic transducers (Figure 1).
- Signal Post Processing to Improve Guided Wave Tests
Experts at TWI undertook a project in 2019 to develop post-processing methods based on split-spectrum processing (SSP) in order to reduce the noise on the guided wave signals caused by scattering. Scattering can occur where a pipeline is buried or covered with a protective coating, reducing signal strength and increasing background noise. To maintain sensitivity, it is necessary to identify small signals that may be within the noise floor. As such, TWI developed
post-processing methods based on split-spectrum processing (SSP) in order to reduce the noise on the guided wave signals caused by such scattering. This project presented the findings of a validation exercise that took data from earlier guided wave tests on highly attenuating pipes, containing deliberately introduced defects. This allowed us to assess the ability of SSP to identify defects in coated and buried pipes which are not detectable using standard guided wave techniques.
- Quantitative Guided Wave Inspection of Pipes
Although guided waves are capable of screening straight pipe for patches of corrosion (Figure 2) and can provide the axial distance of the defect from the tool location and an estimate of cross sectional area loss, the sensitivity is such that a defect must be around 5% of the cross section to be reliability detected. At the time of this 2018 CRP project, available systems couldn’t easily distinguish between a general wall thinning around an entire pipe circumference and a deep corrosion pit. This project addressed these issues by introducing wave modes that had been largely ignored in the past, with data being collected to capture information from these wave modes and using them to detect smaller defects and provide a more quantitative assessment of them (Figure 3).
- Guided Wave Focusing for Pipeline Inspection in the Field
Improvements to the guided wave inspection procedures for pipes helped deliver improved sensitivity for defect location and improved methods for size and shape prediction. However, these advances were only applied to straight pipes with regular wall thicknesses, rather than more complex tubular structures that may have changes in thickness, attachments or weld cap geometry. TWI’s experts addressed this during a 2020 CRP project that investigated guided wave focusing techniques alongside finite element analysis to identify, develop and validate an improved focusing capability (Figures 4-5).
- Guided Wave Flaw Sizing for Pipe Inspection in the Field
Also in 2020, TWI turned its attention to the creation of a robust flaw sizing technique for use with flaws in otherwise inaccessible areas. This would not only allow for better decision making for intervention activities such as excavation but also offer important guidance for guided wave tooling design. This project determined that it was possible to accurately determine the size of a 1.4% cross-section area loss flaw with only 10 degree circumferential extent if at least 12 flexural wave modes are included in the formulation, although this requires improvements to the hardware, such as increased numbers of transmit-receive channels and transducers around the circumference of the pipe. Finite element models found that it was possible to measure the size of flaws lying beyond welds without any modifications to the technique (Figures 6-7). However, for flaws occurring at a weld or lying beyond a pipe support, a correction procedure was required that needs knowledge of the geometry of the weld or pipe support. A correction procedure was successfully developed for a flaw lying at a weld so that it was possible to measure the sizes of flaws at welds with a comparable level of accuracy. However, this still required prior knowledge of the geometry of the weld.
- Signal Processing Techniques for Guided Wave Inspection of Buried Pipelines
Continuing our research into guided wave testing of buried pipelines, this CRP project assessed a variety of improved signal processing methods for data collected on coated pipes. The aim was to increase the capacity of guided wave through an enhancement of the signal-to-noise ratio (SNR). Among the methods tested were the spatial variances method, an adaptive filtering technique, a spectral matching technique, a low frequency testing technique, and the coded excitation technique.
