Development of High Performance Barrier Coatings with HVAF and HVOF
Project Code: 36693
Start date and planned duration: January 2026, 12 months
  • To evaluate the High velocity air fuel (HVAF) spraying process as a means of depositing high performance corrosion and wear resistant coatings for industrial service.
  • Evaluate and compare the performance of HVAF and HVOF coatings with respect to key quality and performance criteria to enable TWI Industrial Members to assess the viability of using the processes in industrial service across a wide range of applications.
  • Evaluate economics for HVAF and HVOF processes to enable TWI Industrial Members to assess the process economics of HVAF/HVOF as alternatives to other corrosion and wear mitigation solutions.
Project Outline
High Velocity Air Fuel (HVAF) spraying is a newly commercialised process variant of High Velocity Oxy-Fuel (HVOF) spraying. HVAF can deposit coatings at lower temperatures compared with conventional HVOF, enabling a key advantage to produce higher quality coatings from carbide cermet and metallic powders to protect parts against corrosion, wear, [MR2.1]and erosion. The application of thinner/denser HVAF coatings (10-50µm) also opens up cost/performance improvements over conventional HVOF sprayed coatings, which are typically ~300µm thick. This project will explore advantages of the HVAF process compared with HVOF, that is already widely used in the industry and will also provide information on material and process selections for harsh environments.
Coatings will be applied using advanced HVOF and HVAF processes which typically use finer powders compared to conventional HVOF, and assessed in terms of deposition characteristics, coating characteristics and performance:
  • Deposition characteristics
  • Microstructure
  • Microhardness
  • Impact damage tolerance
  • Adhesion strength
  • Corrosion performance
Industry Sectors
- Oil and Gas
- Aerospace
- Space
- Defence
- Construction and Engineering
Benefits to Industry
  • Assessment of alternatives to hard chrome plating to allow for legislation compliant coating applications.
  • Evaluation of a new technology, HVAF, with less widely available performance data but significant potential and interest.
  • Potential cost savings and quality improvements from new process and feedstocks.
