Through Weld Cap Inspection Using Ultrasonic Testing
Project Code: 36207
Start date and planned duration: January 2025, 24 months
  • Development of ultrasonic techniques to inspect welds with intact caps including (a) through weld cap inspection using Adaptive Total Focusing Method (ATFM) and conformable probes (b) skew beam inspection from adjacent base metal using linear or 2D arrays
  • Develop a range of test pieces containing representative flaws to support evaluation of developed techniques
  • Experimental testing of developed techniques to assess the feasibility to inspect welds with intact caps using ultrasonic testing
Project Outline
This project seeks to develop ultrasonic testing techniques to enable inspection of welds with a probe located directly on an intact weld cap. The work will build upon existing capability within TWI to generate suitable focal laws to allow focused images of the weld body using the ATFM algorithm.
Flaws of primary interest are transverse planar indications within the weld body or heat affected zone e.g. transverse hydrogen cracking.
Within the scope several low carbon steel test pieces shall be manufactured with a range of weld cap configurations and representative flaws to demonstrate capability and support a portfolio of evidence for this relatively new inspection capability.
Industry Sectors
- Oil and Gas
- Power Generation
- Civil Nuclear
- Defence
Benefits to Industry
  • Ultrasonic testing through an intact weld cap may eliminate the need to remove the cap, offering cost and time reductions associated with machining processes.
  • Supports the industry demand for ultrasonic testing in lieu of radiography. Radiography does not require weld cap removal. If ultrasonic testing can also be performed with the cap intact this increases the range of applications where it may replace radiography leading to:
    1. Improved safety due to removal of ionising radiation
    2. Time and cost savings associated with the removal of radiographic exclusion zones
