Correlation of Mechanical Properties for Steel and Weld Regions
Project Code: 36205
Start date and planned duration: January 2025, 12 months
To identify whether a correlation between hardness and fracture toughness can be determined for steels.
Project Outline
TWI has previously developed correlations between hardness and yield strength for parent materials, weld metals and HAZs in C-Mn steels. These were originally published in TWI’s Industrial Member publication “Bulletin” and have subsequently been incorporated into selected British Standards (Hart, 1975, Pargeter, 1978, BSI, 2019)
Fracture toughness is said to decrease with increasing hardness, but this is quoted as a ‘rule of thumb’, with no manner of determining an approximate value of toughness from hardness. It is important to determine whether this correlation truly exists, or is limited to the findings associated with a single steel composition or could be applied more widely.
The existing body of information available from the TWI Research reports will be searched to identify data concerning hardness and fracture toughness. The data identified will be collated in a database and used to identify whether the correlation of hardness and toughness exists, and if so, develop a relationship to link these two properties.
Industry Sectors
- Oil and Gas
- Power
- Construction
Benefits to Industry
If the correlation can be determined, it would allow approximations of fracture toughness to be made from hardness data, which may arise from weld procedure qualification testing or from failure investigations, where the test material is limited.
