- Quantitative Guided Wave Inspection of Pipes
This 2018 CRP work investigated a range of guided wave modes that had, up until that point, not been used for screening areas of pipe for corrosion (Figure 1). The aim was to see if these previously ignored modes, which all interact differently with different sizes and shape of defect, could capture information that can be used to detect smaller defects and provide a more quantitative assessment of them (Figure 2). This work informed future developments for inspection software to create time savings for the application of emerging quantitative guided wave inspection techniques. The effect of a 90° bend on the guided wave signals in a pipe was investigated for several wave modes and the effect of the bend on an axisymmetric signal was also calculated for four different geometries of bend elbow and welds. Finite element analysis was used to test a time reversal technique for producing a desired signal beyond a pipe bend and a new technique for measuring the axial extent of a flaw was developed and successfully experimentally validated.
- Guided Wave Inspection of Plate-like Structures
Moving away from pipe inspection, this 2019 CRP investigated the use of guided wave inspection for medium sized plate-like components that are inaccessible or hidden, ranging from flat plate structures such as bridges and storage tank floors to large diameter cylinders, like storage tanks walls, pressure vessels and wind turbine support structures. With these inspections, the use of the usual array of transducers as deployed for pipeline inspection was not applicable, so our experts developed and evaluated an ‘omnidirectional SH0 transducer’ capable of successfully ultrasonic guided wave testing plate-like components. This development was aided by finite element analysis ahead of prototyping and testing (Figure 3).
- Guided Wave Flaw Sizing for Pipe Inspection in the Field
This 2020 project investigated flaw sizing for otherwise inaccessible areas to provide reliable information about the dimensions of any flaws detected. Being able to quantify the severity of an anomaly would reduce the requirement for costly intervention such as excavation and inspection to determine the flaw size in a buried pipeline. Being able to determine the physical theoretical capability of the flaw sizing technique would provide important guidance for future guided wave tooling design. This project recommended hardware improvements as well as ascertaining the ability to measure flaw sizes at welds or beyond pipe supports. An experiment carried out for a flaw at a weld showed agreement between the finite element models and the experiment (Figures 4-5).
- Guided Wave Focusing for Pipeline Inspection in the Field
This 2020 CRP project continued from the previous one, with the aim of progressing the use of ultrasonic guided waves beyond simple pipe geometries with constant wall thicknesses. TWI’s experts used a combination of finite element analysis and experimentation to identify, develop and validate an improved focusing capability in situations such as pipes with weld cap geometry, pipe supports, pipe branches, or changes in thickness (Figures 6-7). Four state-of the-art guided wave focusing techniques were assessed, with the most successful being synthetic focusing (achieved through post-processing raw data from an unfocused test) and the analytical dispersion-removal (AD-focus) active focusing method (involving tailored inputs to different segments of the guided wave transmitting tool). Finite element modelling showed that the AD-focus method was successful in a range of set-ups, including different tool configurations (individual points, octants, multiple rings, collar gap), pipe sizes, focal angles, focal distances, and a number of flexural wave modes. These findings were validated by lab-based experiments, showing excellent agreement between model and experiment, giving high confidence in the other modelling results, and in the use of modelling for the development and refinement of guided wave technology.
- Signal Processing Techniques for Guided Wave Inspection of Buried Pipelines
Also In 2020, our experts addressed guided wave signal processing techniques for buried pipelines. Many pipelines are buried in the ground for safety or aesthetic reasons and in these cases non-metallic coatings are widely used to protect the pipe from corrosion. External coatings, which are often viscoelastic in nature, reduce the test range due to absorption of the sound energy into the coating, with different coating types and thicknesses having different effects on the inspection range. In addition, imperfections in the bonding conditions between the coating and the pipe and corrosion in the pipe can increase noise levels and degrade the signal-to-noise ratio (SNR). Our team investigated SNR enhancement through improved signal processing methods for coated pipe data to increase the capability of guided wave inspection.
Joint Industry Projects
Our joint industry projects (JIPs) allow interested parties to come together as project sponsors, pooling resources for greater research outcomes, while also being given exclusive access to the results and the opportunity to guide the direction of the projects themselves. These projects typically focus on challenges faced by specific industry sectors, providing industry-relevant information, guidance and solutions.
- Use of Long Range Guided Wave Ultrasonic Testing for Fitness-for-Service Determination of Pipelines
Announced in 2009, this JIP was created to integrate flaw sizing with fitness-for-service procedures and extend flaw sizing capability to a wider range of pipe diameters. The accuracy of these assessments were then established via validation tests to create validated techniques for the examination of difficult to inspect areas. The evidence that was gathered was used to support the use of the technology for presentation to regulatory bodies.
You can find out more about TWI’s work with the numerical simulation of guided wave inspection, including the support we can provide for Industrial Members, here:
https://www.twi-global.com/what-we-do/services-and-support/asset-management/finite-element-analysis/numerical-simulation-of-guided-wave-inspection
