What are the factors affecting distortion?
  • Parent material properties
  • Amount of restraint
  • Joint design
  • Part fit-up
  • Welding procedure
Parent material properties which influence distortion are coefficient of thermal expansion and specific heat per unit volume. As distortion is determined by expansion and contraction of the material, the coefficient of thermal expansion of the material plays a significant role in determining the stresses generated during welding and, hence, the degree of distortion. For example, as stainless steel has a higher coefficient of expansion than plain carbon steel, it is more likely to suffer from distortion.
Restraint
If a component is welded without any external restraint, it distorts to relieve the welding stresses. So, methods of restraint, such as 'strong-backs' in butt welds, can prevent movement and reduce distortion. As restraint produces higher levels of residual stress in the material, there is a greater risk of cracking in weld metal and HAZ especially in crack-sensitive materials.
Joint design
Both butt and fillet joints are prone to distortion. It can be minimised in butt joints by adopting a joint type which balances the thermal stresses through the plate thickness. For example, a double-sided in preference to a single-sided weld. Double-sided fillet welds should eliminate angular distortion of the upstanding member, especially if the two welds are deposited at the same time.
Part fit-up
Fit-up should be uniform to produce predictable and consistent shrinkage. Excessive joint gap can also increase the degree of distortion by increasing the amount of weld metal needed to fill the joint. The joints should be adequately tacked to prevent relative movement between the parts during welding.
Welding procedure
This influences the degree of distortion mainly through its effect on the heat input. As welding procedure is usually selected for reasons of quality and productivity, the welder has limited scope for reducing distortion. As a general rule, weld volume should be kept to a minimum. Also, the welding sequence and technique should aim to balance the thermally induced stresses around the neutral axis of the component.
