There are a wide range of applications for HVOF sprayed coatings. Primarily developed for wear resistance and mainly used in the aerospace industry, HVOF sprayed coatings have now found applications in many industries. Principal applications are based on corrosion and wear protection, and repair of worn components, where HVOF spraying can offer a technically superior and commercially competitive solution.
Common applications for HVOF coatings include:
- Wear and corrosion protection, e.g. subsea pump internals, impeller wear rings, valve plugs and seats (WC-Co, WC-CoCr, WC-NiCr coatings), slurry pump internals, extruder dies and tips, valve balls and seats, wire drawing equipment, butterfly valve discs, rock drill internals and cutting surfaces, compressor blades, compressor stator vanes, bearing housings, glass plungers (NiCrSiB coatings), Corona rolls and Anilox rolls (alumina and chromia coatings)(hard chrome replacement).
Other, less common applications include:
- Medical, e.g. biocompatible hydroxyapatite coatings on orthopaedic and dental implants.
- Electronics, e.g. dielectric coatings for electrical insulation in power hybrid circuits and heating elements.
- Spray forming e.g. manufacture of thin walled hollow cylindrical objects from pre-shaped cores by spraying of WC/Co, NiCr alloy and stainless steel.
Some examples of HVOF coatings are illustrated below.
See further information about Materials & Corrosion Management or please contact us.
