EHLA (Extreme High-Speed Laser Application) Coatings
Back to Research Reports Elastic Follow-Up in the Context of Fracture Assessment Review of Process Simulations for Metal Additive Manufacturing Flaw Sizing Techniques Using Guided Waves Flaw Sizing Techniques Using Guided Waves Flaw Sizing Techniques Using Guided Waves 32221-2020-hybrid-composite-to-metal-joining 33557-2020-extreme-high-speed-laser-application-ehla-coatings 33557-2020-extreme-high-speed-laser-application-ehla-coatings 32893-2020-mechanical-fastener-coatings-for-corrosion-protection 33557-2020-extreme-high-speed-laser-application-ehla-coatings 33557-2020-extreme-high-speed-laser-application-ehla-coatings Applications, Modelling and Manufacturing Processes for Perforated Composites - Literature Review A Review of High Power, In-Vacuum and Narrow Gap Laser Welding Processes for Thick Section Welding A Review of High Productivity Additive Manufacture Using a Hybrid Laser-Arc Deposition (HLAD) Process A Review of Micro Welding with Fibre and Disc Continuous-Wave Laser Sources A Review of Residual Stress Measurement Techniques Used for Components Produced Using the Selective Laser Melting Process A Review of the Machine GTAW Ambient Temperature Temper Bead Repair Technique for Nuclear Power Plant Components A Review of Weld Repairs of Mar-M247 and Similar Alloys Butt Fusion Welding Procedures and Test Methods Used for PE Pipes Duplex Stainless Steel Welding – A Review of Current Practices In-Bore Multi-Positional Laser Welding In-Process Monitoring of Arc Welding for Quality and Defect Detection Mechanical Fastening Technologies for Steel to Aluminium Joining in Automotive Manufacture Process Capability Study for Friction Stir Spot Welding (FSSW) Resistance Spot Welding with Transition Discs – A Review of Dissimilar Joining Using Transition Materials with Specific Reference to Resistance Spot Welding Surface Modification and Micro-Machining with Pulsed-Laser Sources Wire Fed Electron Beam Additive Manufacture – A State-of-the-Art Review
Extreme High-Speed Laser Application (EHLA) Coatings
By Charlotte Blake and Josh Barras
Extreme High-speed Laser Application (EHLA) is a novel coating technology first developed in 2017 and now entering the market. TWI has acquired the first EHLA system in the UK and is carrying out research to assess the suitability of the technology for various applications. EHLA promises a step-change in coating technology, maintaining a number of the benefits of the conventional Laser Metal Deposition (LMD)/laser cladding process, while addressing some limitations, such as the maximum coating coverage rate, coating thickness (maximum or minimum), surface quality, bond integrity and dilution level between material and substrate.
EHLA technology is similar to laser cladding/LMD, but differs in some details, which result in a significant increase in deposition rate. EHLA coverage rates can be increased to at least 250cm2min-1. This is achieved through an earlier introduction of the metal powder into the path of the laser beam, resulting in lower dilution and ultimately thinner coatings, while using higher power (>1kW) to melt and fuse material quickly. In conventional LMD, the powder and laser beam meet primarily at the melt pool generated on the surface of the substrate. In EHLA a shallower and more quickly solidifying melt pool is generated, with a narrower HAZ. Please see “What is Extreme High-Speed Laser Application (EHLA)?” for more details.
This report provides a brief overview of coating technologies (thermal spraying, conventional LMD, weld overlay, and electrodeposition), and notes the potential Health, Safety and Environmental (HSE) benefits of EHLA for preparing chromium-based hard coatings. The EHLA state-of-the-art and current applications are reviewed; however, this is a new process so there is relatively little published information. Finally, the report includes a short discussion of the growth potential of the technology.
Key Findings
EHLA is an emerging technology for the application of coatings to rotating substrates, with potential for future development to freeform surfaces and additive manufacturing applications. However, while significant knowledge can be carried over from conventional LMD to support the development of understanding around the EHLA process, there are key differences between the technologies. These require detailed investigation, ranging from process physics and modelling, to the characteristics of the resultant materials. Fundamental process research will support the maturing of this technology and strengthen understanding of its applications, benefits, and limitations.
 33557-1-20-1725-Image01
Laser power input, high speed, and powder melting in the beam for EHLA (right) contribute to high coverage rate, thin coatings with low dilution and a narrow HAZ, compared with conventional LMD (left)
