Additive Manufacture using Hybrid Laser-Arc Deposition
Back to Research Reports Elastic Follow-Up in the Context of Fracture Assessment Review of Process Simulations for Metal Additive Manufacturing Flaw Sizing Techniques Using Guided Waves Flaw Sizing Techniques Using Guided Waves Flaw Sizing Techniques Using Guided Waves 32221-2020-hybrid-composite-to-metal-joining 33557-2020-extreme-high-speed-laser-application-ehla-coatings 33557-2020-extreme-high-speed-laser-application-ehla-coatings 32893-2020-mechanical-fastener-coatings-for-corrosion-protection 33557-2020-extreme-high-speed-laser-application-ehla-coatings 33557-2020-extreme-high-speed-laser-application-ehla-coatings Applications, Modelling and Manufacturing Processes for Perforated Composites - Literature Review A Review of High Power, In-Vacuum and Narrow Gap Laser Welding Processes for Thick Section Welding A Review of High Productivity Additive Manufacture Using a Hybrid Laser-Arc Deposition (HLAD) Process A Review of Micro Welding with Fibre and Disc Continuous-Wave Laser Sources A Review of Residual Stress Measurement Techniques Used for Components Produced Using the Selective Laser Melting Process A Review of the Machine GTAW Ambient Temperature Temper Bead Repair Technique for Nuclear Power Plant Components A Review of Weld Repairs of Mar-M247 and Similar Alloys Butt Fusion Welding Procedures and Test Methods Used for PE Pipes Duplex Stainless Steel Welding – A Review of Current Practices In-Bore Multi-Positional Laser Welding In-Process Monitoring of Arc Welding for Quality and Defect Detection Mechanical Fastening Technologies for Steel to Aluminium Joining in Automotive Manufacture Process Capability Study for Friction Stir Spot Welding (FSSW) Resistance Spot Welding with Transition Discs – A Review of Dissimilar Joining Using Transition Materials with Specific Reference to Resistance Spot Welding Surface Modification and Micro-Machining with Pulsed-Laser Sources Wire Fed Electron Beam Additive Manufacture – A State-of-the-Art Review
Capabilities Banner
Innerpage Title Banner
TWI Technical Literature Review 23069
By P Brown
The purpose of this literature review is to investigate the state of the art (SoA) in relation to combining individual areas of additive manufacturing and arc welding technology, namely: laser metal deposition (LMD), hybrid laser-arc welding, and arc welding. These three individual technologies are areas in which TWI has significant experience and expertise, the information linked to combining these techniques, learned from this review, will feed into TWIs future development work.
In the manufacturing world, the term 'hybrid' generally refers to the combining of more than one individual process and/or technology in order achieves a particular advantage over the reliance on a singular process/technology. A common example is a hybrid car, these are designed to be more environmentally friendly than a conventional car (singularly powdered by an internal combustion engine), the hybrid can be propelled by either a petrol engine or an electric motor, or indeed with them both at the same time. This literature review will consider both of these 'hybrid' types ie, the 'in-series' use of more than one process and the 'parallel' use of more than one process.
