A Review of Post-Build Heat Treatments of IN718 PBF Material
Back to Core Research Programme 34236-2023-literature-review-on-the-potential-use-of-non-destructive-testing-techniques-for-residual-stress-measurement 34241-2023-artificial-intelligence-for-ndt-scanning-of-unknown-geometries-using-collaborative-robots 34459-2022-friction-stir-welding-of-pressure-vessel-liners-for-the-storage-and-transportation-of-hydrogen 34727-2023-techniques-for-high-temperature-ultrasonic-inspection-of-arc-welding-state-of-the-art-review 34793-2023-update-on-literature-reviews-for-wire-fed-additive-manufacturing 34847-2023-Literature-review-on-crack-length-measurement-techniques-on-environmental-fracture-toughness-tests 35268-2024-Literature-review-on-dual-sensing-applications-for-SHM-of-pipelines 32221-2020-hybrid-composite-to-metal-joining 32893-2020-mechanical-fastener-coatings-for-corrosion-protection 33557-2020-extreme-high-speed-laser-application-ehla-coatings 33557-2020-extreme-high-speed-laser-application-ehla-coatings 33557-2020-extreme-high-speed-laser-application-ehla-coatings 33557-2020-review-of-electric-vehicle-battery-joining-methods-and-testing 34250-2022-thermoplastic-materials-compatibility-for-hydrogen-service A Review of High Power, In-Vacuum and Narrow Gap Laser Welding Processes for Thick Section Welding A Review of High Productivity Additive Manufacture Using a Hybrid Laser-Arc Deposition (HLAD) Process A Review of Micro Welding with Fibre and Disc Continuous-Wave Laser Sources A Review of Residual Stress Measurement Techniques Used for Components Produced Using the Selective Laser Melting Process A Review of the Machine GTAW Ambient Temperature Temper Bead Repair Technique for Nuclear Power Plant Components A Review of Weld Repairs of Mar-M247 and Similar Alloys Applications, Modelling and Manufacturing Processes for Perforated Composites - Literature Review Butt Fusion Welding Procedures and Test Methods Used for PE Pipes Duplex Stainless Steel Welding – A Review of Current Practices Elastic Follow-Up in the Context of Fracture Assessment Flaw Sizing Techniques Using Guided Waves Flaw Sizing Techniques Using Guided Waves Flaw Sizing Techniques Using Guided Waves In-Bore Multi-Positional Laser Welding In-Process Monitoring of Arc Welding for Quality and Defect Detection Mechanical Fastening Technologies for Steel to Aluminium Joining in Automotive Manufacture Process Capability Study for Friction Stir Spot Welding (FSSW) Resistance Spot Welding with Transition Discs – A Review of Dissimilar Joining Using Transition Materials with Specific Reference to Resistance Spot Welding Review of Process Simulations for Metal Additive Manufacturing Surface Modification and Micro-Machining with Pulsed-Laser Sources Wire Fed Electron Beam Additive Manufacture – A State-of-the-Art Review
By Konstantinos Georgilas
Additive manufacturing of Alloy 718 has been extensively utilised to manufacture engineering components. Alloy 718 is a nickel-iron base superalloy that requires heat treatment to achieve final working properties. Alloy 718 is of special interest for the aerospace and oil & gas sector due to its excellent mechanical and corrosion properties at relatively high temperatures (650°C).
This literature review examines the current state of the art in regards to post-built heat treatment of material produced through Laser Powder Bed Fusion. The detailed parameters used for the treatments have been extracted and summarised. The effect of the treatments on the microstructural properties is discussed specifically, in the context of decreasing the anisotropic nature of the microstructure in the as-built condition. Similarly, the resultant mechanical properties are summarised and discussed.
Key Findings
  • Current research has focused on replicating current heat treatment standards.
  • Current heat treatment temperatures are not sufficient to remove detrimental phases from the microstructure.
  • Increasing the heat treatment temperature dissolves detrimental phases and leads to grain growth, decreasing anisotropy.
