Flaw Sizing Techniques Using Guided Waves
Back to Research Reports Elastic Follow-Up in the Context of Fracture Assessment Review of Process Simulations for Metal Additive Manufacturing Flaw Sizing Techniques Using Guided Waves Flaw Sizing Techniques Using Guided Waves Flaw Sizing Techniques Using Guided Waves 32221-2020-hybrid-composite-to-metal-joining 33557-2020-extreme-high-speed-laser-application-ehla-coatings 33557-2020-extreme-high-speed-laser-application-ehla-coatings 32893-2020-mechanical-fastener-coatings-for-corrosion-protection 33557-2020-extreme-high-speed-laser-application-ehla-coatings 33557-2020-extreme-high-speed-laser-application-ehla-coatings Applications, Modelling and Manufacturing Processes for Perforated Composites - Literature Review A Review of High Power, In-Vacuum and Narrow Gap Laser Welding Processes for Thick Section Welding A Review of High Productivity Additive Manufacture Using a Hybrid Laser-Arc Deposition (HLAD) Process A Review of Micro Welding with Fibre and Disc Continuous-Wave Laser Sources A Review of Residual Stress Measurement Techniques Used for Components Produced Using the Selective Laser Melting Process A Review of the Machine GTAW Ambient Temperature Temper Bead Repair Technique for Nuclear Power Plant Components A Review of Weld Repairs of Mar-M247 and Similar Alloys Butt Fusion Welding Procedures and Test Methods Used for PE Pipes Duplex Stainless Steel Welding – A Review of Current Practices In-Bore Multi-Positional Laser Welding In-Process Monitoring of Arc Welding for Quality and Defect Detection Mechanical Fastening Technologies for Steel to Aluminium Joining in Automotive Manufacture Process Capability Study for Friction Stir Spot Welding (FSSW) Resistance Spot Welding with Transition Discs – A Review of Dissimilar Joining Using Transition Materials with Specific Reference to Resistance Spot Welding Surface Modification and Micro-Machining with Pulsed-Laser Sources Wire Fed Electron Beam Additive Manufacture – A State-of-the-Art Review
Review of Flaw Sizing Techniques Using Guided Waves
By Jane Allwright and Ruth Sanderson
With hundreds of thousands of miles of pipelines being used throughout the oil and gas industry, as well as numerous other pipes and pipe-like structures in, for example, the power industry and many others, there is a strong need to ensure the integrity of large lengths of pipe. This requires the ability to inspect such structures in service, and to interpret the outcomes of such inspections in terms of any flaws or abnormalities that may have been detected. Long range ultrasonic testing procedures using guided waves are currently used to meet this inspection challenge, and provide a means of screening tens of metres of pipe from a single test location.
In recent years, improvements have been made to the guided wave inspection procedures for pipes. Using both finite element analysis and experimentation, methods have been developed to:
  • Predict the size and shape of flaws.
  • Focus the sound energy on particular regions of the pipe, giving increased sensitivity.
One of the main areas of interest in the field of guided waves is to derive quantitative information about flaws directly from the patterns of reflections and mode conversions in a standard guided wave inspection.
The purpose of this review was to understand and summarise this work, to collect together the various results, to establish links between them where possible, and so to identify the state-of-the-art.
