Manual Metal Arc Welding (MMA, SMAW or Stick Welding)
jk21.gifJob Knowledge 2
Manual metal arc welding (MMA or MMAW), also known as shielded metal arc welding (SMAW), flux shielded arc welding or stick welding, is a process where the arc is struck between an electrode flux coated metal rod and the work piece. Both the rod and the surface of the work piece melt to create a weld.
Manual metal arc welding was first invented in Russia in 1888. It involved a bare metal rod with no flux coating to give a protective gas shield. The development of coated electrodes did not occur until the early 1900s when the Kjellberg process was invented in Sweden and the Quasi-arc method was introduced in the UK. It is worth noting that coated electrodes were slow to be adopted because of their high cost. However, it was inevitable that as the demand for sound welds grew, manual metal arc became synonymous with coated electrodes. When an arc is struck between the metal rod (electrode) and the workpiece, both the rod and workpiece surface melt to form a weld pool of molten metal. Simultaneous melting of the flux coating on the rod will form gas and slag which protects the weld pool from the surrounding atmosphere. The slag will solidify and cool and must be chipped off the weld bead once the weld run is complete (or before the next weld pass is deposited).
The process allows only short lengths of weld to be produced before a new electrode needs to be inserted in the welding electrode holder. Weld penetration is low and the quality of the finished weld deposit is highly dependent on the skill of the welder.
Types of flux/electrodes
To strike an arc between the electrode and base metal, such as carbon steel, and to produce a good quality weld, a stick welder must ensure that their welding machines are fitted with suitable electrodes. Arc stability, depth of penetration, metal deposition rate and positional capability are greatly influenced by the chemical composition of the flux coating on the electrode. Electrodes can be divided into three main groups:
  • Cellulosic
  • Rutile
  • Basic
Cellulosic electrodes contain a high proportion of cellulose in the coating and are characterised by a deeply penetrating arc and a rapid burn-off rate giving high welding speeds. Weld deposit can be coarse and with fluid slag, deslagging can be difficult. These electrodes are easy to use in any position and are noted for their use in the 'stovepipe' welding technique.
Features:
  • deep penetration in all positions
  • suitability for vertical down welding
  • reasonably good mechanical properties
  • high level of hydrogen generated - risk of cracking in the heat affected zone (HAZ)
Rutile electrodes contain a high proportion of titanium oxide (rutile) in the coating. Titanium oxide promotes easy arc ignition, smooth arc operation and low spatter. These electrodes are general purpose electrodes with good welding properties. They can be used with AC and DC power sources and in all positions. The electrodes are especially suitable for welding fillet joints in the horizontal/vertical (H/V) position.
Features:
  • moderate weld metal mechanical properties, such as tensile strength
  • good bead profile produced through the viscous slag
  • positional welding possible with a fluid slag (containing fluoride)
  • easily removable slag
Basic electrodes contain a high proportion of calcium carbonate (limestone) and calcium fluoride (fluorspar) in the coating. This makes their slag coating more fluid than rutile coatings - this is also fast-freezing which assists welding in the vertical and overhead position. These electrodes are used for welding medium and heavy section fabrications where higher weld quality, good mechanical properties and resistance to cracking (due to high restraint) are required.
Features:
  • low hydrogen weld metal
  • requires high welding currents/speeds
  • poor bead profile (convex and coarse surface profile)
  • slag removal difficult
Metal powder electrodes contain an addition of metal powder to the flux coating to increase the maximum permissible welding current level. Thus, for a given electrode size, the metal deposition rate and efficiency (percentage of the metal deposited) are increased compared with an electrode containing no iron powder in the coating. The slag is normally easily removed. Iron powder electrodes are mainly used in the flat and H/V positions to take advantage of the higher deposition rates. Efficiencies as high as 130 to 140% can be achieved for rutile and basic electrodes without marked deterioration of the arcing characteristics but the arc tends to be less forceful which reduces bead penetration.
Power source
Electrodes can be operated with AC and DC power supplies. Not all DC electrodes can be operated on AC power sources, however AC electrodes may be used on either AC or DC.
Welding current
Welding current level is determined by the size of electrode - the normal operating range and current are recommended by manufacturers. Typical operating ranges for a selection of electrode sizes are illustrated in the table. As a rule of thumb when selecting a suitable current level, an electrode will require about 40A per millimetre (diameter). Therefore, the preferred current level for a 4mm diameter electrode would be 160A, but the acceptable operating range is 140 to 180A.
What's new
Transistor (inverter) technology is now enabling very small and comparatively low weight power sources to be produced. These power sources are finding increasing use for site welding where they can be readily transported from job to job. As they are electronically controlled, add-on units are available for TIG and MIG welding which increase the flexibility. Electrodes are now available in hermetically sealed containers. These vacuum packs obviate the need for baking the electrodes immediately prior to use. However, if a container has been opened or damaged, it is essential that the electrodes are redried according to the manufacturer's instructions.
Training
TWI's Training School offers an appreciation course on MMA welding. This includes theory and practical sessions, with approximately 75% demonstrations and hands-on sessions; appreciation of the welding processes and fundamental basic knowledge. Health & safety, setting up equipment, welding process parameters, process related defects and how to avoid them, welding consumables.
For more information, please click here.
Enquiries
For more information on MMA welding and tehcncial enquiries please contact us.
