Frequently Asked Questions
There are a number of different surface finishes available; the best one to choose will depend on a product's specific application. Some suggestions are included in the table below.
| Material | Thickness (µm) | Solderability | Reflow Survivability | Shelf Life | Cost | Advantages | Disadvantages |
| Immersion Ag |
0.05-0.20 |
Good |
5 reflows |
12 months |
Medium |
Consistent flat surface for SMT Good electrical probe surface Good solderability |
Must be recycled quickly if mis-screened Not available from all suppliers Multiple board finishes difficult |
SnAgCu HASL |
1-25 |
Good |
5 reflows |
12 months |
Medium |
Good electrical probe surface Withstands multiple process steps Good solderability |
Higher thermal stress process No planar surface for SMT |
Immersion Sn |
0.75-1.25 |
Good |
5 reflows |
12 months |
Medium |
Good solderability Consistent flat surface for SMT Good electrical probe surface |
Must be recycled quickly if mis-screened Multiple board finishes difficult Tin whiskers risk |
Electroless Ni Immersion Au |
5 Ni 0.05-0.2 Au |
V. Good |
4 reflows |
6 months |
High |
Excellent solderability Consistent flat surface for SMT Minimal handling issues |
Expensive 'Black Pad' Multiple board finishes difficult |
SnCu HASL |
1-25 |
Good |
5 reflows |
12 months |
Medium |
Good solderability Good shelf life Withstands multiple process steps |
Wider thickness variation than Sn-Pb HASL Intermetallics formed before assembly |
| Electroless Pd |
0.15-0.40 |
Good |
5 reflows |
12 months |
High |
Minimal handling issues Good solderability |
Thick Pd causes brittle joints Cost Availability |
Organic Solderable Preservative (OSP) |
0.15-0.50 |
Good |
3+ reflows |
12 months |
Low |
Good planar surface Low cost No intermetallics before assembly Strongest solder joints |
Handling concerns; probing issues Difficult obtaining adequate hole fill Narrow process window for multiple passes |
A consideration when changing to lead-free PCBs is that the board itself will need to withstand the higher processing temperatures for lead-free solder applications; this, like many of the changes required to comply with the RoHS Directive, may have cost implications. When considering laminate properties, some organisations are proposing to use other thermal parameters such as the coefficient of thermal expansion (CTE), time to delamination, and decomposition temperature (Td ), as better predictive indicators than Tg (glass transition temperature). Therefore, not only are increases in Tg necessary, but also decreases in CTE and increases in the Td of the material.
For further assistance from TWI on RoHS and WEEE matters, please contact us
What is the WEEE Directive?
