What is the best approach for cleaning ceramics?
In general the method and extent of cleaning depends on the ceramic and final product requirements. However, a suggested general cleaning approach is detailed below.
Typically, the contaminants that may be found on ceramics are ceramic powders (usually the same as the ceramic) from post sintering operations (i.e. cutting) and organics from fingerprints/handling.
The first cleaning operation would be to remove the powder contaminants and soluble organics. This can be achieved by immersion in a solvent (a few of which may be heated to increase their activity) and by agitation in an ultrasonic cleaner (for at least 15 minutes). The next step would be to rinse the solvent and any loose contaminants off the surface. A rinse in de-ionised water would be best, otherwise distilled or tap water (note tap water may leave scale on the surface). Leave to dry, ensuring no debris/contaminants can be picked up.
After drying, the cleaned parts should be placed on clean supports (that have been through the same cleaning and firing cycle as described here). Typically, the parts would then be fired in a clean furnace for >1 hour. The furnace atmosphere and temperature is dependent on the ceramic being cleaned but in general an air atmosphere would be used for oxide ceramics and others with high temperature air stability. Otherwise, inert gas or vacuum environments may be used. On cooling, the parts must be handled with clean ceramic tweezers (metal implements may contaminate the ceramic). If the parts need to be picked-up, powder-free gloves should be used. Note that plastic gloves generally contain plasticisers which can re-contaminate the parts. Cotton gloves could be used, but there is the risk of introducing lint onto the parts, and cotton is hygroscopic.
If the parts are to be stored, then it is recommended that they should be placed into a clean dessicator (which can be under vacuum).
