Frequently Asked Questions
It is almost impossible to predict accurately the amount of weld shrinkage. Nevertheless, a 'rule of thumb' has been composed based on the size of the weld deposit. When welding steel, the following allowances should be made to cover shrinkage at the assembly stage.
| Transverse shrinkage |
| Fillet welds |
0.8mm per weld where the leg length does not exceed 3/ 4 plate thickness |
| Butt weld |
1.5 to 3mm per weld for 60° V joint |
| Longitudinal shrinkage |
| Fillet weld |
0.8mm per 3m of weld |
| Butt weld |
3mm per 3m of weld |
Increasing the leg length of fillet welds, in particular, increases the shrinkage.
If you have any questions or need help, email us to get expert advice: contactus@twi.co.uk.
