Can lasers be used successfully in the microtechnology field?
Frequently asked questions
The laser energy can be guided into restricted access areas, where other joining techniques cannot be used. Nd:YAG lasers are routinely used to produce welds between similar and dissimilar materials. They can produce mechanical joints, as well as hermetic seals between materials. Lasers can also be used as a source of thermal energy to reflow solders. In this instance, a diode laser may allow better process control than an Nd:YAG laser because of the more efficient absorption of the laser energy by the solder.
The importance of laser soldering is now becoming apparent with the proposed removal of lead from solders. The replacement solder materials have higher reflow temperatures, that could result in damage to the parts being soldered. Lasers allow the application of heat to the solder joint only, decreasing the risk of thermal damage to the surrounding parts. Typical applications of lasers include the joining of lead frames, light bulb filaments.
