ICELIP – Ice-Phobic Coating for Aerospace
Icing represents a complex and expensive problem in different industrial and energy applications such as aircraft, wind turbines, and power lines. Ice contamination on aircraft, specifically, is a multifaceted problem with repercussions for safety, efficiency, costs, and the environment. In-flight ice accumulation causes airflow disruption and decreasing control and performance. Large pieces of ice separating during flight can cause problems to engines and impact propellers. Additionally, frozen contaminants can jam control surfaces.
Icing is a major cause of delays, incidents (2.1% of total incidents), and severe accidents (4% of fatal accidents). The next generation of aircraft targets are to reduce drag by 20%, fuel consumption by 4%, and also to reduce CO2 emissions. A clean and smooth wing surface is essential for natural laminar flow (NLF) and reaching those targets.
Current ice-mitigation technologies in flight include mechanical breaking, electrical heating, freezing point depressant fluid and air bleed systems. De-icing systems can add up to 5% to aircraft weight. This increases fuel consumption, costs, and CO2 emissions by 4% and creates potential failure points. De-icing fluids are also used on the ground to remove ice from aircraft prior to take-off, with operations costing over £10,000 per large aircraft, consuming up to 1500L of fluid. Waste should be collected to prevent pollution and meet environmental regulations, as de-icing fluids increase aquatic toxicity and biochemical oxygen demand in waterways.
The use of passive anti-icing technologies, such as ice-phobic coatings, would dramatically reduce these problems. Despite the presence of different ongoing research studies and a few commercial products, no ice-repellent coating is currently able to provide a high degree of durability, particularly for the aerospace industry. The innovative aspect of the ICELIP solution is to provide standard aerospace coating systems with dual functionalities. This will be achieved by using ice-repellent multi-functionalised silica nanoparticles bonded strongly to a standard polyurethane clear coat already used in the aerospace sector. The focus of the innovation is the optimisation of a coating developed in previous R&D work by part of the consortium (TWI, LSBU, CAV, BAE Systems, Innvotek) and supply chain manufacturer, Promethean Particles. Coatings will be tested in an ice wind tunnel simulation environment to demonstrate a combination of ice-repellency and durability (TRL 5-6).
Progression towards passive, durable, and highly ice-repellent surfaces provides immediate opportunities for implementation, as it is designed to be seamlessly integrated into currently used materials. ICELIP technology could also be used in other sectors affected by icing, e.g. other transport (rail, maritime, automotive) and energy (wind turbines, power lines).
The ICELIP project (of which Icemart® is the commercial brand) will help to revolutionise the issue of icing.
Keep up to date on all things Icemart®:
LinkedIn: https://www.linkedin.com/company/icemart/
Twitter: @Icemart2
Or contact the ICELIP project Exploitation Manager David Hannan at Opus Materials Technologies dhannan@opusmaterials.com
Avatar Eur Ing Anna Wojdyła-Cieslak, CEng Principal Project Leader - Novel Polymer Technologies
Anna is a Principal Project Leader at TWI. She received her MSc Eng in Chemical Engineering with specialization in Fuel Technology from AGH University of Science and Technology, Poland, in 2010. After graduation, she worked at the SHR Research Timber Institute in Netherlands, where she gained experience in silicon chemistry and coating technology.
In 2013, she joined TWI Ltd and NSIRC, where she was involved in European and UK founded collaborative projects and was sponsored by TWI Ltd to undertaken a PhD degree in assessment of advanced coatings and surface treatments at Brunel University in London. Her research was focused on the development of novel assessment criteria for durability evaluation of highly repellent surfaces. Over the period of the PhD programme Anna published two peer review papers and several conference articles.
In 2016, she joined TWI Ltd staff as Project Leader in the Functional Coatings and Resins department, where she has major technical involvement in European and UK funded projects as well as Single Client.
