How Robotics Could Transform Wind Turbine Blade Inspection
01
Inspecting the Next Generation of Wind Energy Infrastructure
Wind turbines are becoming an increasingly important part of electricity generation, placing greater emphasis on the reliability and long-term performance of their components.
Among the most critical are the blades, which must combine low weight with sufficient strength and stiffness to withstand demanding operating conditions.
Modern wind turbine blades are manufactured using composite materials, typically incorporating glass fibres and polymer resins. These materials provide an effective combination of mechanical performance and relatively low weight, but their layered structures also present particular inspection challenges.
Damage may develop within the composite without being fully visible at the surface.
Delamination, voids, cracking and erosion can affect the integrity of a blade, potentially reducing its performance and service life.
Traditional inspection methods may identify external damage, but assessing the condition of the underlying composite structure can be more difficult.
Researchers at TWI have been investigating how advanced non-destructive testing (NDT) techniques can improve the detection of damage in wind turbine blades.
By combining automated inspection equipment with digital data acquisition and analysis, the work aims to support more reliable assessments of composite blade integrity.
The research focuses on two complementary methods: automated tap testing and advanced microwave inspection.
Both have been evaluated using robotic inspection systems, demonstrating their potential to identify damage that is not immediately apparent through visual examination alone.
02
Why Wind Turbine Blades Are Difficult to Inspect
Wind turbine blades operate in demanding environments throughout their service lives.
They experience repeated mechanical loading, exposure to changing weather conditions and environmental effects that can gradually affect their condition.
Their composite construction introduces additional challenges.
Unlike a homogeneous metallic component, a composite blade contains reinforcing fibres embedded within a resin matrix. The structure may include different material types and internal features, depending on the blade design and manufacturing process.
This construction provides important performance advantages, but defects can occur during manufacture or develop during operation.
Typical forms of damage include delamination between composite layers, internal voids, cracking and surface erosion.
Some defects can be identified through visual inspection. Others may exist beneath the surface, where their extent cannot be established by appearance alone.
For large wind turbine blades, access also presents a practical problem.
Removing a blade for detailed inspection can be difficult and disruptive. Inspection methods that can eventually be deployed on installed blades therefore offer considerable potential value.
The challenge is to identify techniques capable of detecting internal damage while remaining practical for large composite structures.
The Limitations of Visual Inspection
Visual inspection is an important first stage in assessing blade condition.
It can identify surface cracking, erosion, impact damage and other visible abnormalities.
However, the external appearance of a composite component does not necessarily reveal the full extent of internal damage.
A relatively small surface indication may be associated with a larger affected region beneath the outer layers.
Consequently, additional inspection methods are needed to evaluate suspected damage and provide more detailed information about the condition of the material.
TWI's investigation examined whether automated tap testing and microwave inspection could provide this additional information.
The objective was not simply to detect visible damage, but to determine whether the methods could identify indications of volumetric damage within the blade structure.
03
Bringing Automation to an Established Inspection Technique
Tap testing is a long-established method of assessing the condition of composite structures.
Traditionally, an inspector gently taps the surface of a component using a specially designed hammer and listens for changes in the resulting sound.
Differences in acoustic response can indicate variations in the condition of the material beneath the surface.
Although the principle is relatively simple, conventional tap testing relies on the inspector's ability to recognise and interpret changes in sound.
Modern systems use a transducer to measure the response, allowing the results to be displayed and recorded digitally.
TWI has taken this development further by integrating tap testing equipment with a collaborative robotic arm.
The robot provides controlled movement of the inspection sensor across the component surface, while digital processing software captures and visualises the resulting information.
This approach reduces reliance on subjective listening and creates a digital record that can be reviewed after the inspection.
For wind turbine blades, automated tap testing offers a potentially practical means of identifying areas of internal damage across composite surfaces.
The technology also provides a foundation for developing more repeatable inspection procedures, particularly where large structures require systematic examination.
Using Microwave Technology to Detect Hidden Damage
The second technique investigated by TWI uses microwave inspection.
Unlike conventional ultrasonic testing, microwave inspection uses electromagnetic radiation to examine the internal characteristics of suitable non-metallic materials.
When microwaves interact with a composite structure, changes in the material's electromagnetic properties can affect the reflected signal.
In particular, variations in relative permittivity associated with internal features or defects may produce detectable responses.
These changes can be analysed to identify potential damage within the material.
TWI developed an automated microwave inspection arrangement using a collaborative robotic arm to position the inspection sensor.
The system incorporates TWI's Crystal Software Development Kit (SDK) to support data acquisition and processing.
This allows the recorded microwave responses to be converted into visual information that can assist an inspector in identifying areas of interest.
Microwave inspection provides a complementary approach to tap testing.
Both methods are intended to reveal information about the condition of a composite structure, but they rely on different physical principles.
Investigating both techniques on the same component therefore provides an opportunity to compare their responses to suspected damage.
Putting the Technologies to the Test
To evaluate the inspection methods, TWI conducted trials on a wind turbine blade that had been removed from service because of suspected damage.
The blade was positioned on the ground inside an inflatable, weatherproof enclosure.
An initial visual examination identified areas of possible damage on the external surface.
The researchers also suspected that damage might extend into the internal composite structure.
Both automated tap testing and microwave inspection were then applied to the blade.
The inspection arrangement used a Universal Robots UR10e collaborative robotic arm.
The appropriate sensor was attached to the robot depending on which inspection method was being performed.
TWI's Crystal SDK supported robotic path planning, data acquisition and analysis of the inspection results.
What the Inspection Data Revealed
Both inspection techniques produced indications consistent with volumetric damage.
Importantly, the recorded data suggested that the affected regions extended beyond the damage visible on the external surface.
The researchers compared the inspection results with the locations identified during visual examination.
The areas highlighted in the tap testing and microwave datasets corresponded with the visibly damaged regions of the blade.
This provided encouraging evidence that both methods could identify areas of suspected internal damage.
However, the investigation had not reached the stage of complete physical validation.
The original article stated that further confirmation would be undertaken by sectioning the blade and comparing the exposed internal condition with the recorded NDT data.
The results should therefore be understood as a successful initial demonstration rather than proof that either method had been fully validated for routine inspection of operating wind turbines.
04
Towards More Reliable Wind Turbine Blade Inspection
The initial trials demonstrated the potential of combining robotic automation with non-destructive testing techniques designed for composite structures.
Both automated tap testing and advanced microwave inspection identified indications of volumetric damage in a wind turbine blade removed from service.
The recorded data suggested that the affected regions extended beyond the damage visible on the surface.
This is an important finding because external inspection alone may not reveal the full extent of deterioration within a composite component.
The use of a collaborative robotic arm also demonstrated how inspection sensors can be positioned and moved systematically across a blade surface.
Digital acquisition and processing provided a record of the inspection results, allowing the researchers to visualise and compare indications from the two techniques.
The Potential for In-Situ Inspection
One of the longer-term objectives of the research is to develop methods that could be applied to wind turbine blades without dismantling them.
In-situ inspection could provide significant practical advantages, particularly for large wind turbines where component removal is complex.
The ability to examine areas susceptible to damage during maintenance activities could support more informed decisions about repair and continued operation.
However, further development and validation are required before the techniques can be considered established methods for routine in-service inspection.
The original study identified destructive sectioning of the trial blade as a necessary next step to confirm the internal condition indicated by the NDT results.
Future work would also need to address the practical challenges of deploying automated inspection equipment on installed blades.
Supporting the Reliability of Wind Energy
As the use of wind energy expands, maintaining the integrity of turbine blades will remain an important engineering challenge.
Composite structures require inspection techniques capable of identifying damage that may not be apparent from their external appearance.
TWI's investigation illustrates how established methods such as tap testing can be enhanced through robotics and digital data processing, while newer approaches such as microwave inspection offer additional opportunities for examining non-metallic materials.
Although the reported work represents an initial stage of development, the results provide a promising basis for further investigation.
With appropriate validation and deployment development, these technologies could contribute to more effective blade condition assessment and improved maintenance planning for wind energy infrastructure.
Media /
Our Stories
How AI Is Transforming Non-Destructive Evaluation
Discover how artificial intelligence is helping NDT inspectors analyse complex data, identify ...
Discover how TWI is combining robotics, tap testing and microwave inspection to ...
To discover more, please contact us:
