What are Nanoparticles? Definition, Size, Uses and Properties
A nanoparticle is a small particle that ranges between 1 to 100 nanometres in size. Undetectable by the human eye, nanoparticles can exhibit significantly different physical and chemical properties to their larger material counterparts.
The definition given by the European Commission states that the particle size of at least half of the particles in the number size distribution must measure 100 nm or below. Most nanoparticles are made up of only a few hundred atoms.
The table below shows the size of nanoparticles compared to other structures:
Particle Type
Diameter Size Range
Atoms and small molecules
0.1 nm
Nanoparticles
1 to 100 nm
Fine particles (also called particulate matter - PM2.5)
100 to 2,500 nm
Coarse particles (PM10, or dust)
2500 to 10,000 nm
Thickness of paper
100,000 nm
The material properties change as their size approaches the atomic scale. This is due to the surface area to volume ratio increasing, resulting in the material’s surface atoms dominating the material performance. Owing to their very small size, nanoparticles have a very large surface area to volume ratio when compared to bulk material, such as powders, plate and sheet. This feature enables nanoparticles to possess unexpected optical, physical and chemical properties, as they are small enough to confine their electrons and produce quantum effects.
For example, copper is considered a soft material, with bulk copper bending when its atoms cluster at the 50nm scale. Consequently, copper nanoparticles smaller then 50nm are considered a very hard material, with drastically different malleability and ductility performance when compared to bulk copper. The change in size can also affect the melting characteristics; gold nanoparticles melt at much lower temperatures (300 °C for 2.5 nm size) than bulk gold (1064 °C). Moreover, absorption of solar radiation is much higher in materials composed of nanoparticles than in thin films of continuous sheets of material.
What are the Uses and Applications of Nanoparticles?
Nanomaterials can occur naturally, be created as the by-products of combustion reactions, or be produced purposefully through engineering to perform a specialised function.
Due to the ability to generate the materials in a particular way to play a specific role, the use of nanomaterials spans across a wide variety of industries, from healthcare and cosmetics to environmental preservation and air purification.
The healthcare field, for example, utilises nanomaterials in a variety of ways, with one major use being drug delivery. One example of this process is whereby nanoparticles are being developed to assist the transportation of chemotherapy drugs directly to cancerous growths, as well as to deliver drugs to areas of arteries that are damaged in order to fight cardiovascular disease. Carbon nanotubes are also being developed in order to be used in processes such as the addition of antibodies to the nanotubes to create bacteria sensors.
In aerospace, carbon nanotubes can be used in the morphing of aircraft wings. The nanotubes are used in a composite form to bend in response to the application of an electric voltage.
Elsewhere, environmental preservation processes make use of nanomaterials too - in this case, nanowires. Applications are being developed to use the nanowires - zinc oxide nanowires - in flexible solar cells as well as to play a role in the treatment of polluted water.
In the cosmetics industry, mineral nanoparticles – such as titanium oxide – are used in sunscreen, due to the poor stability that conventional chemical UV protection offers in the long-term. Just as the bulk material would, titanium oxide nanoparticles are able to provide improved UV protection while also having the added advantage of removing the cosmetically unappealing whitening associated with sunscreen in their nano-form.
The sports industry has been producing baseball bats that have been made with carbon nanotubes, making the bats lighter and therefore improving their performance. Further use of nanomaterials in this industry can be identified in the use of antimicrobial nanotechnology in items such as the towels and mats used by sportspeople, in order to prevent illnesses caused by bacteria.
Nanomaterials have also been developed for use in the military. One example is the use of mobile pigment nanoparticles being used to produce a better form of camouflage, through injection of the particles into the material of soldiers’ uniforms. Additionally, the military have developed sensor systems using nanomaterials, such as titanium dioxide, that can detect biological agents.
The use of nano-titanium dioxide also extends to use in coatings to form self-cleaning surfaces, such as those of plastic garden chairs. A sealed film of water is created on the coating, and any dirt dissolves in the film, after which the next shower will remove the dirt and essentially clean the chairs.
Controlling the size, shape and material of the nanoparticle enables engineers to design photovoltaics (PV) and solar thermal products with tailored solar absorption rates. Absorption of solar radiation is much higher in materials composed of nanoparticles than in thin films of continuous sheets of material.
The Sol-Gel process is a method for producing solid material from nanoparticles. Whilst it is generally viewed as a relatively new industrial technology, it is used extensively in a number of industries, such as abrasive powder manufacture, coatings production and optical fibres.
How Can TWI Help?
TWI has a long history of working with its Members on nanoparticle technologies. Please contact us to learn more.
Sources
  1. https://www.bbc.co.uk/bitesize/guides/z8m8pbk/revision/1
  2. https://www.sciencedaily.com/terms/nanoparticle.htm
  3. https://www.britannica.com/science/nanoparticle/Nanoparticle-applications-in-materials
  4. https://www.news-medical.net/life-sciences/What-are-Nanoparticles.aspx
Related FAQ: What is a Nanomaterial? - Definition, Examples and Uses
