Automated inspection of nozzle welds in nuclear environments
Connect no. 172
Regular in-service inspection is important to verify the integrity of welded nozzle sections in nuclear and other safety critical facilities. Nozzle sections made from austenitic steel can be susceptible to rapid crack growth due to thermal fatigue and stress corrosion. Early detection of cracks is therefore essential to ensure the continued safe operation of the facility in question.
Nozzle inspections require a variety of inspection techniques and equipment. The process necessitates the plant is shutdown for several weeks which leads to lost production and profitability. Although automatic or semi-automatic inspection equipment has been introduced for many applications operators are nevertheless still exposed to radiation during the equipment set-up and certain operational activities. Currently inspection is undertaken using a number of conventional ultrasonic probes. As the probes need to be changed to allow full inspection of the nozzle weld areas and each change demands recalibration, defect detection and sizing capabilities are not optimum. Furthermore, as the current probes have no beam steering capability a large and expensive robot is required to provide accurate manipulation.
To reduce the time and cost of such inspections there is an urgent need to develop a system capable of performing a full inspection of nozzles without changing probes.
Such a system would offer the following clear benefits:
  • Faster inspection times.
  • Improved defect detectability and sizing.
  • Reduced human intervention which will reduce workforce radiation uptake.
  • Reduced requirement for robotic manipulation and consequently reduced size and cost of robotic deployment system.
The objective of this project is to develop a system that will use a scanner and manipulator robotic
assembly for an automatic inspection of nozzle welds.
The automatic robotic assembly will carry a novel matrix phased array probe which combined with the 3D beam steering capability, will enable a large area of the weld to be inspected in a single operation.
