New mechanised system for electro-spark deposition
Connect, no. 120, September/October 2002, p.7
Electro-spark deposition (ESD) is a micro-weld-surfacing process used for localised coating and build up repair. With one or two exceptions coatings are, at present, applied manually using a hand held coating applicator. However, TWI has recently adapted an ESD system for mechanised operation.
Mechanised ESD on gas turbine blade airfoil
An ESD coating applicator has been attached to a simple counter-balanced pivot arm fixed to a 6-axis robot. The applied force is varied by adjusting the load at the opposite end of the pivot arm.
The purpose of this new facility is to improve coating quality whilst increasing deposition rate. The very low heat input that ESD imparts to the substrate allows materials, otherwise susceptible to heat affected zone cracking, to be surfaced.
Robot mounted ESD applicator and pivot arm
Examples of fusion welding sensitive materials that can be surfaced using ESD include nickel superalloys for gas turbine blades and tool steels.
